Updating references
Command |
Path |
Shortcut |
Organization |
Tools |
Ctrl+Shift+O (Windows) Cmd+Shift+O (Mac) |
Referenced design layers and resources are either updated automatically when the target file is opened, or they are updated manually upon command. These preferences are set in either the New Reference or the Edit Reference dialog box. If the file is set to update automatically, manual updates can still be performed at any time.
Before an update, correct any broken references as described in Correcting broken references.
To update references manually:
Select the command.
The Organization dialog box opens.
From the References tab, select the master files that contain the referenced items to be updated.
To update all references in the target file, select all of the files.
Click Update to update the referenced items in the target file from the selected files.
If priority updating is disabled (recommended), referenced items are always updated from the original file.
If priority updating is enabled, referenced items are updated according to the priority order on the References tab.
For more information about priority updating, see Setting the referencing options, and Prioritizing referenced files.
Most references update automatically. However, when updating a single reference to a DXF/DWG/DWF, Revit, or IFC file, the appropriate dialog box opens to confirm or adjust settings as needed; see DXF/DWG and DWF import options, Importing Revit, or Importing IFC files.
If a referenced item is missing, the Referenced Resource not Found dialog box opens. Select an action option.
Parameter |
Description |
Break the reference |
Breaks the reference with the master file, leaving the resource in the target file |
Delete the resource |
Deletes all occurrences of the resource in the target file |
Replace resource with |
To replace the missing resource with another item from the master file, select this option, and then select the replacement item from the list of available resources |
Click OK To All to perform the same action for all missing resources. To select an action for each missing resource individually, click OK; the dialog box redisplays for each missing item.
